07-31-2024
12:06 PM
07-31-2024
03:44 PM
computergeek541
Hello,
I recently switching phones and when I try to access my voicemail, it says the number is not set.
Checked a few threads and looks like I need to get in touch with @CS_Agent
Hoping someone can help.
Thanks!
Kevin
07-31-2024 12:40 PM
@KB-1981, I've always accessed my voicemail by dealing my number on my own phone which is also mentioned in Public Mobile's article:
How To Access Your Voicemail From Another Phone
https://www.publicmobile.ca/en/bc/get-help/articles/voicemail-faqs
07-31-2024 12:37 PM
Thanks @will13am I tried that, but still same issue. I've reached out to CS
07-31-2024 12:37 PM
That's exactly what I did, but it still has that same error.
I've reached out to file a ticket with CS
07-31-2024 12:36 PM
Usually the system would push the voicemail number to you. Try reboot the phone couple times, and Reset All Networks.
if it still not pushed, then you need to manually set it. You can set it on yoru dial app, settings, look for voicemail
You can set it to this number 778-580-4001
07-31-2024 12:33 PM
@eddieO, I'm just pressing and holding the "1" button for voicemail. I thought it was pretty standard for it to just be set.
07-31-2024 12:28 PM
How did you switch your account on the new phone?
All you need to do is put the old SIM in the new phone and your account will automatically switch over to the new phone including voicemail box.
07-31-2024 12:13 PM
@KB-1981 , the voice mail number is generally set by the network. Try toggling airplane mode and deleting the cache on the phone app.
07-31-2024 12:10 PM - edited 07-31-2024 12:19 PM
@KB-1981, are you dialing your own complete number from your new phone? Once it has been set I didn't think it would matter if you changed phones since it should be setup on your account
07-31-2024 12:08 PM
@KB-1981, To get a hold of a CS_agent you can open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
