10-19-2023
01:13 PM
10-21-2023
03:29 AM
computergeek541
Every time when an incoming call leave a message, it will become a outgoing call to the message centre?
10-19-2023 01:19 PM
hi @pat001
yes it is normal, but it won't cost you outbound minutes, if you are in $15 plan. But remember, checking voicemail from your phone will cost you the minutes
10-19-2023 01:17 PM
unanswered calls will go to your voicemail. If you have the $15 plan with limited calling minutes, be aware that checking your voicemail use up minutes.
