08-20-2026 12:59 PM - edited 08-21-2026 12:15 AM
08-20-2026 08:34 PM
If you want to keep your number while away for 6 months…just pay your monthly plan but make sure your CC on file won’t expire while you are away or your account will be closed and loss your number for nonpayment for longer than 90 days.
If you want to save money for your plan but it is a lot of work try to login to your account every 86 days on the website. Have the 2FA code sent to your email to login to your account to suspend and activate your account.
You pay for 3 month payment. Suspended 1st month, active 2nd month, suspended 3rd month, active 4th month, suspended 5th month and active 6th month when you return. Not sure if you want to do this or just pay your monthly plan.
08-20-2026 02:08 PM
You have to pay subscription at least once in 90 days. Ideally on 85th day. After first no-payment your account will be suspended and if Not paid within 90 days it will be cancelled, number lost.
PM does not have 'hold the account' if you are not using it.
08-20-2026 01:08 PM
PM only allows the account to be suspended for 90 days or your account will be permanently closed, and you will loss the number.
So, your option is temporarily suspending the account and reactivate for 30 days before the 90 days deadline.
Here is what you can do:
