Data
05-05-2022 04:51 PM
My Data is often turned off before I use the full amount. Public mobile tells me I have used all my data which I have not. How do I solve this problem, other than changing providers
Service
05-05-2022 08:39 PM
Does a data line exists here under your overview section in your self serve account @Sherrynchls ?
https://selfserve.publicmobile.ca/Overview/
If the data line is still showing, try below troubleshooting to help regain data services:
- restart your phone
- toggle into and out of airplane mode
- perform a Reset of the device's Network Settings
Also, try your SIM into another compatible phone to see if data works then. Just to rule out a phone issue.
05-05-2022 05:44 PM
You can look into you self serve as well to see the daily usage (web) but that data/add on meter is the ultimate go to for accurate numbers
05-05-2022 05:44 PM
You can look into you self serve as well to see the daily usage (web) but that data/add ons meter is the ultimate go to for accurate numbers
05-05-2022 05:27 PM
Log in to your account / My data and add-ons. You'll see how much data you've used of your current allotment of data. If you see no mention of any data...that means, in fact, you've used it all until (a) next regular scheduled renewal (b) you renew plan early (c) you buy a data add-on for use until next regular renewal occurs.
Make sure to use your wifi whenever possible to economize on your data.
05-05-2022 04:55 PM
@Sherrynchls Are you on Android? Any chance you have setup a data limit on your Mobile settings? PM is using a 30 days cycle and the start day of each cycle will change. The data limit setting on the device would not work unless you change the cycle start date every month
This is a sample screen with data limit enabled and the cycle start date set at 13th of each month. But it won't work well with PM 30 days cycle. If you have it, you should disable the "Set Data limit"
