Data
10-27-2018 08:52 PM - edited 01-05-2022 02:19 AM
10-27-2018 09:29 PM
is your phone unlock? open network? Try to reset and if it doesn't work go to settings
cellular data APN should say isp.mb.com leave username blank and password blank hope that helps.
also take out sim and re-insert.
10-27-2018 09:13 PM
what phone are you using?
10-27-2018 09:06 PM
APN password lock on when I changed to public mobil
10-27-2018 08:58 PM
@acb59s96Acan you provide more info? as to teh problem? if its a password on your phone no one on the community can help you.
