Data
Nanette234
How do I get more data on my phone and how much will it cost
dabr
@Nanette234    Add-on data prices have changed for the better recently, so you could purchase 1GB for $10 under Add-ons selection in My Account (30 days) or, if you have enough points  to redeem in your Rewards page, then you can redeem 5 points for 5GB data for 30 days usage which is really good value vs purchasing similar amount for $20/5GB in My Account.
@Nanette234  It’s also possible with the help of support to do an early renewal , and pay for plan again immediately and start new 30 day cycle with  new data bucket for 30 days depending on your typical data usage and plan your on this might be the better option to pursue
you can use the orange chat bubble bottom right of screen  or send  a  private message   To CS_Agent
@Nanette234 you can buy data add-on (30 days expiry):
3GB Add-on - $30.00 (20 Reward points)
1GB Add-on - $15.00 (10 Reward points)
200MB Add-on - $5.00 (5 Reward points)
But only buy enough for the rest of your current cycle
If you need way more data that what data add-on offers or you need more data every month, you might want to consider changing plan to one with more data
