Data
Sunil21
Hi
I had a 250G of bonus data, this month I changed my monthly plan now it is not showing anymore.
Please help
Thanks
Sunil xxxxxx
416-xxx-xxxx
@Ben434 wrote:
Got a link to that complaint office? I too would love to.
Sent info to your private mailbox in the top right corner.
Ben434
Ben434
Is that for real? For clarification, first they cancel loyalty bonus, then give me 250 gigs of extra data (which are only used if I go over the 40 I have, which I don't typically get close to). They then put an expiry date on the bonus data (which again I likely won't use). Then if I downgrade my plan so that I can use the bonus data, they take the bonus data away? Am I understanding that correctly?
Chalupa_Batman
Sadly what they say is true. Public Mobile is basically forcing everyone to pay the exact same amount or more to keep a loyalty gift given to customers for their loyalty. But threaten to remove said gift if you lower your plan after removing your loyalty credits. I have filed a complaint with the CCTS over this.
https://productioncommunity.publicmobile.ca/t5/Announcements/Upcoming-Changes-to-our-Old-Rewards-Pro...
Yummy
If you downgraded your plan - switched to cheaper one then your loyalty bonus is gone and you cannot get it back at all. 😞
Dunkman
@Sunil21
Unfortunately, if you downgraded your plan, you will lose the bonus data add on.  It was in the FAQ document that Public mobile announced.
https://www.publicmobile.ca/en/bc/get-help/articles/move-to-public-points
Will I lose my special bonus data if I switch plans?
The bonus data will remain active unless your account becomes inactive, you switch to a plan of lower value or to an incompatible plan.
P.S I will remove your personal information from this public forum
