Data
Carriej
I got data from my rewards, but the data isn’t working. The regular data is working fine.
Donnn
gpixel
PM should have at least done a vote wether or not customers would like unlimited throttled data or non expiring data add-ons. I believe most of us would've chosen the non expiring data add-ons
Chalupa_Batman
Do you have the app on your phone? If so, log in and check your add ons. Also note that "CANADA ADD-ONS
Data add-ons expire after 30 days." Did you use your points to purchase it today?
@Carriej  Data add on will only get used once’s you use up your plan data bucket . So if you used up all plan data . Reboot the phone if your add on data not kicking in automatically like it should
