03-22-2023 12:25 PM
When walking does my fitness app and another app that I listen to (audiobooks, meditations, etc) use data? Almost reached my data limit for the month.
03-22-2023 02:44 PM
What device do you have?
Most devices have a data usage feature that can inform you of the amount of data you've used and break it down by app usage as well.
Search your settings for data usage.
03-22-2023 12:36 PM
@North16 , expect all apps to use data to do synching and various things in the background. For podcasts, it should be possible to download episodes while at home connected to WiFi. I believe it is possible to control app background data usage. That said, the amount of background data is pretty small.
03-22-2023 12:30 PM
If you stand alone apps - not needing Internet then none of those apps will use your data UNLESS you keep data on all the time and THEN all these aps Will connect to see 'what is new' or sync steps with server.
03-22-2023 12:29 PM
If you have cell data on and streaming things from the internet then of course it uses data. You might want to trim down all the apps that use data in the background. And set OS and app updates to only run when on wifi.
