07-30-2018 08:23 PM - edited 01-04-2022 06:35 PM
07-30-2018 09:01 PM
@newf2456 are you looking at the Usage History page? If so, data usage is only reported once per day. What you are seeing is the total usage over the previous 24 hours. That is why the numbers appear larger than you would expect for that time of day--becuase it's not just for that time of the day, it's the whole day.
07-30-2018 08:32 PM
Hi,
If you have any questions concerning your account, just send a private message through the following link :
07-30-2018 08:30 PM
Check the settings in your phone to see if there are any auto account data backups, or sync with pictures and media to the cloud, etc. Turn those off if you don't intend to do so.
Hope this helps and good luck.
