11-01-2022 02:21 PM
Hi all,
I just started a new cycle, and on the public mobile website it says I have already used 1000.3 mb / 1024 yikes!
However on my phone , when checking the same time period, it says I have only used 124. Has anyone else found that their usage is different? Whats going on!
Thanks
11-01-2022 02:27 PM
worked!
11-01-2022 02:27 PM
blessing thank you
11-01-2022 02:24 PM
HI @n8te try clear cache and restart browser
or try to use Private/Incognito mode
or try on another browser or another device
with one of the ways above, you should see the real usage
11-01-2022 02:23 PM
Try using different browser. Try Incognito mode. Clear browser’s cache. Try forced refresh. Click on little spinner refresh icons lower down.
