Nothing Phone 3a Pro
RaeX
Is the Phone 3a Pro suppported on public mobile networks for Volte and 5g? I cannot find the info anywhere. The public mobile website checker requires me to check using an IMEI, which I can't check without buying first. I know this phone has compatible 5G bands, but is the phone accepted on Public Mobile's whitelist?
2 REPLIES 2
@RaeX
i saw your message before it was gone.
Yes, A059P , 3A Pro does not compatible with Telus either, so it won't work on PM
TelusNothing3AProA059PTelusNothing3AProA059P
@RaeX the 5G on Nothing Phone will work.  But from what I know, Nothing Phone is still not on PM's VoLTE whitelist at the moment.
Add: the phone does not even VoLTE compatible with Telus, so it won't be compatible with PM
Nothing3AProA059PNothing3AProA059P
I would not suggest you to buy the Nothing phone if you are planning to use it on PM network.  Nothing phone does not have a 3G band so you won't be able to make voice calls at all as its VoLTE is not compatible with PM's
