Data usage at limit
Mylest
How do I speak to a rep to investigate this?
@Mylest
I would suggest you check your account first or call 611 on the updated data usage first before contacting a CS_Agent.
Your account under View My View on the current usages with dates, amount and what was use for.
@Mylest  - your plan data amount is listed here in your self serve account under Plan Details:
https://selfserve.publicmobile.ca/Overview/plan-and-Add-ons/ChangePlanLandingPage/
Your plan data, and any addons you may have, would be listed under your main Overview tab on self serve.
If the Plan data line does not exist, it means you used it all up for this cycle:
Then there is the usage details you can try and work through the different pages to view usages here: https://selfserve.publicmobile.ca/Overview/viewUsageChangePlan/
But note, the details are not update immediately. Expect a 6-12 hour delay from when the data was actually used in this area.
JL9
Thee so very rarely an error in these cases, your self serve is very accurate. Many times it's inadvertent usage when wifi is unknowingly turned off or you're downloading or using internet with data either fully or partially
Yummy
Always check status of your data through self-serving account. Do not trust too much SMS telling you are almost done with data nor counters on your phone.
If you keep your DATA on all the time, some background apps/OS might use it without your knowledge.
@Mylest give us more info and we can try to help
To open ticket with PM:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
dust2dust
What limit? On your phone? Does your account show no data under my data & add-ons? Did you get a warning text at 75% and 95% from 611?
