2 weeks ago
Cut and pasted this "Data speeds reduced to a maximum of 512Kbps after your included high-speed data bucket is exhausted."
Does this mean that on the $15 NO DATA plan you would have data at 512kps if you exhaust a $5 data add on?
2 weeks ago
@Wayworn wrote:Thanks for clarifying -- since I mostly use wifi I almost made the mistake of downgrading to the $15 plan.
You wouldn't have been able to downgrade to the $15 plan as it's currently only available for "new activations". Cheapest plan available to existing customers is the $19 plan with 1GB data.
2 weeks ago
2 weeks ago
2 weeks ago
@Wayworn , only 5G speed plans that do not have US roaming included are provided with unlimited throttled data.
