2 hours ago
I have the 15 GB Data within Canada and the US at 5G Speed
Will I be able to use it while I am in Hawaii? Any settings I need to change?
Thanks for answering.
2 hours ago
Thanks a bunch Handy1!
2 hours ago
hi @MDao yes it works. Many tried and confirmed
make sure you connect to T-Mobile or AT&T and prefer to use 4G
Also, turn in roaming data on the phone
2 hours ago
@MDao Yes it will work , just make sure to have data roaming turned in in phone settings . And network to 4g/LTE not 5G and connect to T mobile or AT&T some have said version works now too so be sure to text all 3 and use what works best for you
