Data plan doesn't work, "no internet connection"
eajhealy
When I am outside, away from my home internet and in my car, my phone says "no internet connection". I try to get the internet connection but I simply can not get it.
What can I do to get the connection? My profile says I had the internet connection because my data plan says it is used up, yet, my phone says "no internet connection", and when I go to Google to write something, again, it says "no internet connection".
If this keeps up, I'll have to change providers.
Can anybody help, please?
@eajhealy
You will need to purchase additional data in the Add-on section if your data is all used up or go to an upgraded plan with more data.
Timer
@eajhealy
go to your settings check out mobile data is on ,  and check APN (publicmobile.ca)
Yummy
You just answered your own question. You USED UP all your data. Check your account (NOT while driving) and if you do not see any reference to data allowance, you used up it all.
You can always buy data add-on and continue connecting to Internet until next renewal.
dust2dust
If the area in the middle of your account page is showing a solid red bar and 100% used then you've used all your plan data.
There is no throttled unlimited here. Data just stops.
You can buy data add-ons or ask the support people to do an early renewal or change plan immediately to a new plan.
hairbag1
Make sure data is enabled in settings on the phone.
