05-28-2023 12:53 PM
Plan is good until June 5th, only used 800+ mb of data of 2 GB, and data isn't working properly for the last 4 days. Reset port numbers and all that, reset wifi and Bluetooth settings, still... My data isn't working. I am not a new customer, and I expect you to convince me to stay with you PM, or I will just go to a reliable service provider. This is disgusting.
Service
05-28-2023 01:29 PM
Great oppositional stance right off the intro... But, that would involve buying another phone just to test my sim, no thanks. Also, this phone isn't a year old.
05-28-2023 01:19 PM
don't chew my head off too...but can you try that sim in a different phone. That'll help determine if issue is phone or network related.
05-28-2023 01:11 PM
@NathanWires I can appreciate your frustration.. I’ve been there myself , hopefully they can find a solution for you .
05-28-2023 01:10 PM
My apologies, I am pretty angry about this poor service the last few days. Can't receive or send phone calls. Sent them a private message, thank you for your help.
05-28-2023 01:03 PM
@NathanWires I’m just a customer like you trying to help , if you need support her the link
- while your already here and logged in the community
- you can send a private message To CS_Agents by clicking here.
05-28-2023 01:01 PM
Yes, Data is on, I am not new...
I told you how much data I have used, I looked before posting.
I told you the plan is active until June 5th, seriously??
You are not convincing me to remain a customer... Did you even read what I posted in the first place.
05-28-2023 12:55 PM - edited 05-28-2023 12:56 PM
@NathanWires Is data turned on , on your phone also check you have data left like this
simply try refreshing the page when logged in
and finally is your account active
add can you try SIM card in another phone and see is services work as they should may need to reset network settings
