Data not working
GheorgheCh
Hello
The data on my phone is not working even if I have the data plan with 20Gb of data valid until June 11
Please help me resolve this issue
Thanks
12 REPLIES 12
RavingRaven
@GheorgheCh
Which model? Older LG phones have an issue with the APN updating. You can try powering off your phone. Remove the pm Sim card. Wait 10 minutes and reinsert your pm sim card and see if the APN repopulates the PM APN. Otherwise you will need to edit your APN as supplied above.
@GheorgheCh
you can contact support here
Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Login" and finally click "Click here to submit a ticket ↗
But most data issue is a local device setup problem, it might be quicker if you check the following first:
if it is an iPhone, update the iOS and update Carrier Profiles, then click Reset network settings
if it is an Android,  compare the APN settings below, try to update it and save:
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
         or    default,mms,agps,supl,fota,hipri
           (might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
                or  Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
RavingRaven
@GheorgheCh
You can send them a private message. (Or use the chatbot by clicking the message bubble at the bottom right.) But they have closed for the day so the community can continue to troubleshoot with you if you want to try and resolve the issue tonight otherwise customer support will reply to your private message box tomorrow.
GheorgheCh
It is an LG phone
The data worked then I went to Europe for a 1.5 months, and now I am back to Canada, the phone works but data doesn't...
GheorgheCh
How do I get support from Public Mobile staff?
Please let me know
Thanks
RavingRaven
@GheorgheCh
What type of device are you using? Did your data stop working or never worked?
GheorgheCh
Thanks, I just did
GheorgheCh
Yes, I have a data limit by nothing is used this month, so it should work, but it didn't
GheorgheCh
Hi, yes the data is on, and I have restarted the phone, but it didn't help ...
RavingRaven
@GheorgheCh
Use the arrow at the right of your post to edit out your phone #.
Has the data ever worked on your phone? Do you have your data limiter enabled on your phone? The default is usually 5gb. Do you have data remaing on your plan? Login and confirm.
Rastin
As for your data have you checked in the settings to see if it's turned on
Rastin
This is a public forum please remove your number use the down arrow on the right in a circle to edit
