03-28-2024
06:50 PM
03-28-2024
10:23 PM
computergeek541
hi I just activated my Pm account yesterday and my data doesn't seem to be working I have an iPhone and everytime I turn my wifi off to use data it just says to turn data on or connect to wifi and it won't let me set up a personal hotspot either? Help please
03-28-2024 07:49 PM
HI @Mown_goat
you tried everything you can already, it is time to ask CS agent to check. please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
03-28-2024 07:48 PM
I reset my network settings and tried with the sim on a different phone also didn't work and restarted my phone right after I put the sim back in still doesn't work
03-28-2024 07:31 PM - edited 03-28-2024 07:31 PM
@Mown_goat wrote:Yes I've restarted the phone multiple times since installing it And yes calling and texting both have been working recently
Sounds like you just need to reset your networks like I suggested. 🙂
03-28-2024 07:07 PM
03-28-2024 06:56 PM - edited 03-28-2024 06:57 PM
Hello @Mown_goat
If you've used the phone on a different provider before, please go into your network settings and reset all the networks. You may lose some saved WiFi spots/passwords and some bluetooth saved items. Then reboot the phone. If that doesn't work, have you tried your SIM card in a different phone to see if that works? If it does work, then slide it back to your phone and restart it.
03-28-2024 06:55 PM
@Mown_goat Have you restarted the phone with the PM sim installed? Do voice calls both incoming and outgoing and texting (SMS) work?
03-28-2024 06:52 PM
make sure that Data is enabled in Settings
