Data not working
Walster1
No data for a couple of months now. Data when at WiFi but not outside wi-fi areas, like car. Also, when I click on Mobile Phone Plan message says "Public Mobile has no provisioning website".
10 REPLIES 10
Well then I'm Warren Buffett. 🙂
This is a self-serve provider. Go into your apn settings and add a new one or edit what you have to:
APN Settings:
Name: whatever you want
APN: sp.mb.com
MMS proxy: mmscproxy.mobility.ca
MMS port: 8799
APN type: default,mms,dun
APN enable/disable: APN enabled - probably on anyway and greyed out
MVNO type: GID
MVNO value: 4D
Save, then select to use, then go in and out of airplane mode
HALIMACS
You can ask the "provider" @Walster1
All of us here are just other customers like you;  we're not public mobile employees.  Perhaps you may have been unaware you were not dealing with Public Mobile staff on this community forum.
To contact a Customer Support Agent, send a private message to them by clicking here.  You’ll need to be logged into your Community account for the link to work.
Watch for their response in your Community private mailbox which will be indicated by a number on the small envelope icon to the left of your Community avatar, or tap your Avatar down in Messages.
Walster1
Sorry, this is above my pay grade. Provider should be able to talk English to me.
Walster1
Yes, talk and text works. My phone is a Umidigi Power 7S, has powerful battery, Android 11, 4GB, Model MP06.
Walster1
No, I cannot try another phone with SIM. Phone calls are working fine. My account shows 0 GB used this month.
Walster1
canada
HALIMACS
@Walster1
Just to be certain, you're in CANADA while trying to access data, correct?
Or are you in USA with a US add-on or a Canada-US plan?
dust2dust
Can you try your sim in another phone? Do you see data available in your account?
hairbag1
@Walster1
assuming talk and text work...right ? What make / model is that cellphone ?
Hollister
@Walster1
Check your apn settings https://apn-canada.gishan.net/en
