Data not working on Ulefone Note 16
simonc-s
I got a new phone but the data doesn't seem to work with my SIM card and this phone. It only shows options for 4G, 3G & 2G. Does it have something to do with it being LTE?
1 REPLY 1
@simonc-s
is that Ulefone Note 16 Pro?
if it is Ulefone Note 16 Pro, it should have the proper 3G and 4G bands to make the proper data connection
Please check the APN settings below and update accordingly:
APN: sp.mb.com
        (or try all upper case SP.MB.COM)
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
         or    default,mms,agps,supl,fota,hipri
           (might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
                or  Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
