03-20-2020 02:05 AM - edited 01-05-2022 10:00 AM
I just added money to my account so I can add some data. I added today’s I wanted n then shortly after I got a message saying I used 75% of my data. I did not use it yet.
03-20-2020 03:46 AM
@Minniepin, what do you mean by I added today? How many data add ons have you added? If you find yourself adding more than one, its better to immediately switch up to the $50 plan with the 8.5 gigs of data if on autopay. You can always switch back after.
03-20-2020 02:15 AM
IIRC, the 75% and 95% data usage applies to the plan data only. There is no warning for the add-on data.
Which plan do you have?
03-20-2020 02:13 AM - edited 03-20-2020 02:15 AM
You have to do more than just add money, you need to use that money to buy a data add-on if you want data.
Getting more data is a 2 step process. Step 1 add money. Step 2 choose and use those funds added to buy the add-on. Please see this link https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/HOWTO-Purchasing-Add-ons/m-p/198974
Kudos to @srlawren
