Data not toped up on to 12gig
Scottd239
I am on the old 90 day plan with 12 gigs of data. I used all my data last cycle. My plan was auto payed today but the data was only topped up to 5.389 gigs not 12 gigs. Can someone help me with this.
10 REPLIES 10
@Scottd239
So you only used 0.005393gb out of 12gb according to your response.
Phew.. That's a nice feeling then, you're good with no hoops to jump through lol
darlicious
@Scottd239
Lol....thats the pm data buffer. You basically haven't used any data at all other than you have turned your mobile data on.
To pre-verify your account include in your private messaging only your full name, address, email, phone # and 4 digit acct pin#.
@Scottd239  Mystery solved!!! Now you can enjoy the rest of the 12282 MB of data!!
dust2dust
The left number is used. The right number is the bucket size.
Scottd239
It says
12 gig.      5.393  /  12288 MB
So it only 5.393 mb not gigs
dust2dust
Yes are you sure it's not showing 5.389 / 12288 MB? I'm not exactly sure how the 12 gig's looks but the 5.389 may just be an initial buffer of data. Watch those decimal points and units.
You could provide an image of your overview page.
HI @Scottd239
that is a wieird number.     how it shows on your My Account?  does it say
12 GB Data      0 /5.389
or does it shows
12 GB Data     6.611/12
Open a ticket with CS Agent and check with them
darlicious
@Scottd239
Contact them quick and they might answer you tonight. Otherwise leave a detailed message and they may reset your data counter overnight.
To pre-verify your account include in your private messaging only your full name, address, email, phone # and 4 digit acct pin #
@Scottd239   At My Account, is the next renewal date showing correctly for  July 21 (90 days from today)?
Open a ticket with PM Support and provide them with the screenshot of the data shows in your My Account.  To open a ticket with PM:
1. If you have access to My account: Click on the bubble on the lower right or https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
