Data is not working
Bushkin82
Hi, looks like I'm joining the growing ranks of people whose data is not working. Happened to me this morning. Submitted a ticket and heard nothing back so far, seems a lot of you are not getting a response. What is going on??1
8 REPLIES 8
ORNGNBLK
@Bushkin82  If you already have a eSIM and have to repurchase one, PM should reimburse the value.
Bushkin82
Hi, I sent the information requested and my data is still not back today. It's extremely important that I have my phone for my work and I will need it by Monday. Is Public going to refund me when I am forced to buy a temporary SIM card and plan?
Bushkin82
Update: CSM_PA got in touch yesterday. I sent the info they requested. Today, data is still off.
Bushkin82
Done all that', didn't make a difference. Calls work.
CSA_PM
Customer Support Agent
Hello @ Bushkin82,
I sent you a private message. You can view and reply to it by accessing this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
Dunkman
@Bushkin82
Also noticed a few posts about data issue.
Ticketing/private message system is not working properly.
Try the previous suggestions. If not, I have escalated your post to CSA_PM.
hi @Bushkin82
what phone do you have?  any chance you are BC ?  There is a active service outage in Cranbrook, BC at the moment
https://www.telus.com/en/bc/outages
Or you might want to try Reboot your phone and Reset network settings on the phone
ORNGNBLK
@Bushkin82  what kind of phone do you have? im guessing you have reset network settings, toggled on/off airplane mode, swapped your sim (if physical) to another phone to test etc etc?  Does everything else work? text calls
