Data getting used up faster then normally
Barbarah1
Hi I have been with public mobile for 4 years. I love it its hassle free with the preothorized payments. Only in the last couple months have I noticed my data is draining and im running out unlike normally. I have wifi at work and at home so I don't use much data but seems like it just disappears. Anybody else have this?
1 REPLY 1
@Barbarah1   PM data tracking is usually fairly accurate.
Did you check if any app using background data unnoticed?  Or you have Cloud backup Sync turned on, and not set as use Wifi only?
Best to avoid using data is to turn off Mobile Data completed
If you are on Android, you can check your Mobile Data usage page.  Change the Cycle start date to match your current PM cycle start date, it will show you how much data used and which app used most the data.
