Data and phone calls not working
Melis1990
Hello I paid for 90 days of service on May 21, 2018.
Today I am unable to make any phone calls or use data. When I try to make a phone call I am told it can't be completed and to call *611- when I do that it also says it can't be completed and to go to the website help section.
It was working a few hours ago, I am not over on my data and have unlimited call minutes.
How can I fix this?
LEGO
@Melis1990
Try to toggle Airplane mode.
Try to power down, remove and reinsert your SIM and power on your phone again.
Melis1990
 Thank you, I will try that
Macpandamanda
Hi, I would recommend pulling your sim card and powering off your phone. If its still not working after completing a sim pull and power cycle i would contact the moderation team.
@Melis1990, unless you made some sort of changes on your phone,  I recommend you send a private message to the moderator team so that they can sort this out for you.
Click here to send the moderator team a private message. Their hours are: Mon-Fri 9AM-9PM(EST) & Sat/Sun 9AM-7:30PM(EST)
You can find information regarding the moderator team by following this link.
