02-21-2023 12:53 AM
02-21-2023 06:11 AM
@awfmilton My Account is now up, you can check your data usage and account stastus easier now
02-21-2023 06:10 AM
@awfmilton self serve is up and running I just signed in also check you have data left here
Try again incognito mode/private mode or a different device or lap top or simply try refreshing the page when logged in
02-21-2023 05:45 AM - edited 02-21-2023 06:04 AM
Definitely not "us people" @awfmilton
We're customers just like you on this community, not Public Mobile staff.
You do, however, have every right to express your displeasure with public mobile directly, here's how!
02-21-2023 02:15 AM - edited 02-21-2023 02:18 AM
it is true site is down for maintenance, but usually it wont affect data service
And, does your voice service work?
call 1.855.4PUBLIC to see if Account status is active and if you have data left
chexk if yiu have a data limit enabled on your phone? disable it if you have one set
02-21-2023 01:09 AM
Double check to see if the Cellular Data is enabled on the Settings.
If it is, the could be an outage in your area. Check the outage map:
02-21-2023 12:53 AM
My data stopped working, so I tried to log into my account and that's not working either. You people are costing me money, fix it asap
