07-20-2021 10:56 PM - edited 01-06-2022 02:51 AM
07-20-2021 11:01 PM - edited 07-20-2021 11:04 PM
Purchasing a data add-on is a 2-step process:
1. Loading the fund, you will see the Available Fund in My Account increased by the amount you have just paid
2. Actual purchase of the Add-on. After purchasing the add-on, the Available Fund on My Account will be reduced
Maybe people missed step 2. They just loaded the fund and thought the add-ons were there. Is there a chance you missed it?
You can confirm that you have purchased the Add-On:
1.in the Transaction History you should see 2 entries: load the fund and use the fund to buy the add-on
2. Available Funds will revert to $ 0 (assuming you have no Available Funds previously)
3. The Overview tab on My Account should have an entry on the add-on you purchased
So if you confirm that you have followed both steps and see the Add-On entry, all you need to do is restart the phone.
If you are having difficulty accessing the add-on you purchased, post your screenshots of the 3 things to check here and we can try to help you.
07-20-2021 10:58 PM - edited 07-20-2021 10:59 PM
@Carolinewilliam : Do you still see at least $15 in your Available Funds? If so then you need to go back in to Purchase Add-ons and buy the add-on. It's a non-intuitive 2 steps. Deposit money then buy add-on. The first step really looks like you've gone about buying the add-on but you've only just deposited the money.
07-20-2021 10:57 PM
@Carolinewilliam Do you see it under your account in self-service? Buying addon is a 2 step process - add funds, and then buy addon itself.
