Data add on
Alanashaw
I purchased 3 gigs of data as an add on four days ago. It shows up in my payment history but not on my add ons tab. How do I start using it?
@Alanashaw  .reboot the phone and
Try again incognito/private mode
And or lap top /computer
                    OR
simply try refreshing the page to check data plan / mins / add ons
HI @Alanashaw
just reboot your phone and try to use it.
and for My Account,  could be a cache problem so you don't see it.  You can use Incongit/Private/secret mode on your browser and login My Account again  and it should show
dust2dust
Click on the little spinner refresh icon by the shop add-ons button.
Is this the roaming data? If so is this a re-buy of the same one?
