04-29-2018 01:00 PM - edited 01-04-2022 04:11 PM
I bought a US data add on -200MB yesterday to use while I was in the United States for the day. The add on did not work even when I turned on data roaming and restarted my phone. What can I do with the unused data I payed $10 for? It expires in 10 days. But I was unable use it during my visit.
04-30-2018 01:30 PM
@srlawren Thank you for the details!
04-30-2018 01:29 PM
Thank you @mimmo !
04-30-2018 01:25 PM
@teresachlee I agree with @mimmo, I think your next step is to contact the moderator team via private message. Here's the details you need to know to do so:
04-30-2018 10:59 AM
@teresachlee thanksfor the update. from my limited experience once the addon is showing is should work on PM side. This leaves the 2 possibilities PM had an issue delivering, or user/hardware.
in either case i would message the mods to see if there is anything they can do.
04-30-2018 10:49 AM
04-29-2018 01:45 PM
@teresachlee adding to what @mimmo said, here is a description of the 2-step add-on purhcasing process for your reference. In addition to what @Anonymous said, here's more info on Available Funds balance and how it gets used up.
04-29-2018 01:08 PM
@teresachlee, To add to what @mimmo mentioned, if you never actually bought it, the funds are still in your account and will be used to pay for your next renewal.
04-29-2018 01:05 PM
@teresachlee the first thing to check is if the addon was actually purchased. does it show in you overview page or is there available funds in your account balance.
If the first you could ask the mods if there is any way they can credit you for the purchase, if the second then you never actually bought it.
