07-28-2019 05:33 PM - edited 01-05-2022 06:09 AM
I don't see an option for this as the 30 bucks for 1 GB seems pretty steep. Imo.
Also second question. Is that I have two plans with pm any way someone can swap me some data?
My internet at home has been out for a bit and I didn't realize it till I was chewing through it. On my one line.
Thanks
07-28-2019 07:09 PM
Unfortunately pm doesn't provide any data sharing.
@GinYVR gave you a great suggestion the best thing would be to wait for your data to run out and then renew. If you didn't fix your internet issue best would be to upgrade. You will still get all the rewards coming to you, so keep eye on it. If you want to keep the same plan you will need to ask mods to do it, keep in mind that they are busy these days and respond very slowly especially for non emergency, so make sure that you have the other sim close by and available while waiting in a case your internet gives again
07-28-2019 05:54 PM
@hairtothepie wrote:I don't see an option for this as the 30 bucks for 1 GB seems pretty steep. Imo.
Thanks
It has been said before, most other providers charge something like $10 for 100mb... And PM add-ons are in your account until used up, whether that's in 2days or two years.
You could tether off the second phone?
If you are on an in-market plan right now, you can switch to another plan with different/more data immediately ( you'll forfeit any remaining services on your current plan if you do an immediate pln change) and as soon as that is active, schedule a change back to your preferred plan on your next renewal.
(There is also the option to put the amount needed into your available funds and ask the moderators for an early renewal. But seeing how badly they are backed up, it would take several days to get your data bucket refreshed. It would be my very last resort, for my personal usage even after the add-on.)
07-28-2019 05:45 PM
@hairtothepieYou can always renew early and upgrade to a plan with a larger data bucket.. and downgrade next month if you wish.
07-28-2019 05:45 PM
Yup kinda figured the data prices.
As for the data from one account to another they would be a way if things where in place for it but with a system like this it will never happen.
Shouldn't have asked when I knew the answer.
07-28-2019 05:43 PM
Thanks
You must have the wifi-cell data failover set.
How would one go about swapping data anyway?
07-28-2019 05:36 PM
The data addons are the same price, 3G speed or unthrottled.
unlikely to share data across plans as each plan has its own account.
