Voucher
kriissmiiss
I bought two vouchers from Walmart Canada one being 64 and the other being 45 so I can top up my account for 50/m how do I top up the 45 because it keeps telling me that’s incorrect for nxt month
2 REPLIES 2
hairbag1
Sounds like there's system wide problems loading vouchers so....
If everything else fails...you'll need to contact a moderator for their help.....Click this to message moderator
Please be patient as it could take 48 hours to get a response...usually much less.
Good luck.
hairbag1
You can try again in an hour.
You can try adding it by calling 611.
Let us know if anything works.
BTW...you sure you got a $64 voucher ? Never hearda that.
