Data Usuage
Grace_L
Hello,
I only used 25% of data. Why I received a message that I already used 75%?
SmartAlecTrisha
Maybe it is on your cellphone settings. You can change the data usage settings. Change it to how much GB you have. Mine is set for 8 gb so when I reach 7 gb it warns me. I had it set at 2 gb before and I was getting the warning but still had tons of GB left
Click on the little spinner refresh icons lower down or use private mode. The numbers should update.
@Grace_L   The message could be wrong and you can ignore if you checked using Incognito mode and confirmed that you didn't use 75% of the data
BTW, do you have any bonus data, like the Christmas bonus? how much you have used your bonus data or data add-ons you purchased?  I think the 75% could be a calculation of the total data you got and not just your per cycle data.
Grace_L
Hello,
My plan renewed on Oct 08. Yesterday I already got a message that I used 75% of data.  That’s quite impossible that I consumed that much data just in a few days. I work from home use home Wi-Fi most of the time. And I logged in my account today, it shows that I only use 263 mb out of 1000mb.
@Grace_L
With this new PM site, you might be  reading off the cached version, so the usage you got was not up to date
An easy way is to click the Spinner on the bottom right of the section to force a refresh.
If you don't see an updated usage still, try to login My Account using Incognito mode (or InPrivate for Edge, Private for Safari) or try again with a completely different browser like Edge/Firefox/Chrome.  You should then see the latest usage from the server.  Check again that way to confirm if you really have used 75% of the data
