10-13-2022 05:25 AM
I am experiencing difficulty accessing my account.
My Account
10-13-2022 05:26 AM
@Syreta I just on My Account a minute ago without issue
What is your access problem? password related?
First try to use Incognito mode to access My Account and see if it works
But if you forgot your password, try using the Reset Password link there
If that still does not work, open ticket with PM Support:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
