05-14-2017 08:13 PM - edited 01-04-2022 01:47 PM
Hi:
I am new to PM but noticed an issue of inaacurate data usage in "my account". After three days my phone and two independent data trackers indicate more than 50% less than the amount PM claims I used (I wrote to a mod who says the site is being fixed). Is this an unusual issue? Will it really be fixed?
01-12-2018 12:08 PM
Hey @Picasso1, you are responding to a really old thread and one that's been marked as "Solved" so it would be a better idea to create a new thread for yourself.
In any event, is the PM-claimed usage for the same time period (since Jan 4)?
You could also send a private message to the moderators by clicking here and providing your email address, phone number and your problem description. 🙂
01-12-2018 11:34 AM
This is BS, Public Mobile is inaccurately calculating my data usage. My phone states I've only used 1.18gb from Jan 4 to now, and PM claims I've used 4.6gb of data. I knew there was a catch to Public Mobile cheap plans, screw the customer on Data Usage.
05-16-2017 12:48 PM
@srlawren wrote:@naddude first of all, double check that you don't have WiFi Assist enabled on your iPhone. That will use mobile data even while connected to a WiFi network.
Secondly, the sample set you're looking at is very small. Give it a few more days or a week or so and check again. I think you should find the percentage of difference will decrease.
Thank you.
05-16-2017 12:46 PM - edited 05-16-2017 02:06 PM
@kav2001c wrote:There are a couple of threads about this (incl mine)
Last month our data use / tracking stats dissapeared (around April 25th)
When they resumed the new stats (around early May, probably 5th or so) the stats show we are using ALOT more data than we previously did
Two possibilities
1- System was tracking wrong before and they corrected it
2- System is tracking wrong now and needs to be corrected
But something happened at the end of last month
I also have no difference in how I use my phone but Public's website is showing ALOT more data being consumed (like I am talking an extra gig in past month)
Go into your use history and manually add up what site says
Go to main page and look at number displayed for total used
There is a significant difference
This isn't due to losing packets or something on the phone end
Exactly.
This is what I was interested in: understanding and not "complaining about."
It seems that the PM web site is very irratic and I was just interested in how they calcualte it. I didn't appreciate the insulting, sarcastic, and demeaning posts from others who think they were being "helpful". They were not.
05-16-2017 12:39 PM
@RLBL wrote:
@Garry wrote:
Holy Christ.....Its only 16mb were talking about.
As far as I'm personally concerned, you have nothing to bitch about until you reach 250mb. That would constitute a fair assessment of your comparisons.
Making a case over 16mb is just foolish. The mods have more important tasks to attend to.Agreed 100%.
I just checked my usage for this month:
My Phone (Android N6) says I have used 1.81 GB since my last start date (90 plan); PM says I have used 1.836 (a difference of 25MB on an almost 2GB sample size. That is statiscally accurate to +/- 1.4%, assuming I have used around that much data which I assume I did given two trackers put me in that ballpark)
Another point to mention is that opening a web page, or an app updating can use a couple of MBs to a couple of hundred of MBs of data. Squacking over a delta 8MB is downright silly (especially when you are only using a 8-16MB data sample size... that is like estimating your phone's SOT - screen on time - after it has been off the charger for 5 minutes)
Thanks for your (silly) helpful reply.
Have a great day!
05-16-2017 12:37 PM - edited 05-16-2017 05:51 PM
Clearly you have nothing better to do than troll posters.
It wasn't the amount of usage but the way it is calculated which is irratic. Today My usage was reduced by another 5 megs notwitstanding everyone's insitance that it was accurate.
Thanks for your hospitalty (i.e. hostility)
You'd "catch more flies with honey than vinager."
05-16-2017 12:16 PM - edited 05-16-2017 12:18 PM
Two possibilities
05-16-2017 08:06 AM - edited 05-16-2017 08:09 AM
Agreed 100%.
05-15-2017 07:46 PM
05-15-2017 06:44 PM
05-15-2017 03:27 PM
05-15-2017 02:47 PM - edited 05-15-2017 02:57 PM
I checked the history on your site : 2 megs
My phone 8 megs
my independent tracker : 8 megs
2nd indpeendent tracker 8 megs.
Your total on the "plan" part of my account: 16 megs (not true)
How is one ever to know what the real usage will be?
BTW I have been on WIFI most of the time ......
05-15-2017 02:42 PM
I have checked them and I have responded. I've also verified on my end and it only shows that 16MB was used - can you please log into your self-serve account to confirm this?
I also looked at your usage and I was able to calculate the same amount - now 16116KB used @naddude
Mary
05-15-2017 02:36 PM
Check my private message and my actual data history on your site and you see a wildly different decreapcy.
05-15-2017 02:10 PM
As mentioned, you only consumed 16MB- which is really a small amount (16050KB, only enough to open a page or open an app and browse a few pages) @naddude
Mary
05-15-2017 02:00 PM
Mary: I have not made any big chnges to my system and the iPhone settings tracker of data has always been very accurate. So the problem is at your end. At this point although the descrepancy is about 50% the amount of data is small. I will keep an eye on your site to endure it was a one time only descrepancy and not a trend. Still how do you account for such a large difference? I was with Telus mobile for more than 15 years and never expereinced this. I know you are using the same system so how does this happen?
05-15-2017 01:11 PM
Thank you for your reply!
We don't double usage - the usage shown on our end is accurate. Have you upgraded any apps or the OS of your phone? These could also be the root of the issue and the reason why your data consumption is so high @naddude
Mary
05-15-2017 12:56 PM - edited 05-15-2017 01:02 PM
@Mary_M wrote:Good morning @naddude,
Thank you for reaching out to us!
I have sent you a private message - rest assured that you have only consumed about 16 MB 😃
Cheers,
Mary
Hi Mary:
That is the problem.I have actually only consumed 8 mgs of data according to my iPhone and independent tracker. So I wonder how PM calculates its usage? If it's a trend PM is doubling my actual usage on a continual basis them 3 gigs will only equal 1.5 gigs.
05-15-2017 09:24 AM
Cheers,
Mary
05-15-2017 08:48 AM
@clarkbrand wrote:
I am new to PM and have tracked data for a few days, the amounts have been within a few points of eachother although PM is higher. I see they do round up to 10kb so that explains it being slightly higher.
Every carrier does round up in some way. The 10 kB round up is clearly noted as footnote 4 on the plan page. When I was with Wind Mobile, they would round off to the nearest 1 MB for roaming data. I would end up paying more for round off than actual data used. Everytime the phone synced on new email or message receipt, I would clock at least 1 MB of data. It was terrible.
05-15-2017 12:34 AM
05-14-2017 11:03 PM
05-14-2017 10:51 PM - edited 05-15-2017 08:49 AM
How much data have been consumed? There is round off on the Public Mobile data tracker with each batch of data. Over time with a reasonable amount of data used, the Public Mobile data tracker is pretty close to other data trackers including the stock one on android. So don't expect great comparison after using 5 megs of data. Of course this could be a he said, she said thing. On what basis is the Public Mobile data tracker incorrect?
05-14-2017 10:45 PM
As you state 50% more is a big difference. you have done what you are supposed to contact a mod. they will look into it and get back to you.
now when you say 50% are you stating 2gb vs 4 gb or 100 mb vs 200mb. I know when i auto renewed last week there appeared to be some phantom usage 50-100 mb cant remember exatly, but it could have simply been cycle times or something so i dint gve it much thought.
05-14-2017 10:42 PM
05-14-2017 10:09 PM - edited 05-14-2017 10:11 PM
@RogerI wrote:That's odd. In my experience, my phone tracker, and the PM web site are very close. Within a a % most of the time.
Well yes, isn't that the point of my post?
The site is not.
05-14-2017 09:20 PM
05-14-2017 08:56 PM - edited 05-14-2017 08:58 PM
OK. Once again simply put: the data usage in "my account" on public mobile is double what I am actually using (as monitored by) : my iphone itself, and two independent apps which manage data flow. So What apps I am using is irrlevant. Thanks
05-14-2017 08:40 PM
hoping this doesnt add to the confusion, but if you're not on wifi, and if you dont have certian settings turned off, applications can use data in the background
05-14-2017 08:35 PM
I don't think you understand my question or I am not asking it in a clear fashion. I am not doing anything. My cell phone and independent tracker apps are idicating my useage at 50% less than it is indicated in "my account" at public mobile.ca.
