data usage
Kosmosg
Public Mobile support
I have been trying to check my usage for the last week.  I checked every day but the usage is the same.  Why? I don't mind usage does not increase but I just need to plan my usage for the rest of the cycle
thanks for your help
7 REPLIES 7
hi @Kosmosg usage could got stuck with app too.  But with app, you need to pull the screen down to force a refresh
Kosmosg
hi htidegnow
thanks.  Yes, with that mode, I can see the differenr data usage now.
And you talked about app, I have not used yet, would it show the correct usage without the need of that mode?
hi @Kosmosg click on the 3 dots on top right of the Chrome Window and click New Incognito tab and try login
Kosmosg
I am using Chrome
hi @Kosmosg what browser you have?
or you can try using app as well
Kosmosg
Thanks
but how to access that mode?
hi @Kosmosg
maybe just browser cache, please use Incognito/private/secret mode on your browser to login My Account to confirm again
If same,  please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
