2 hours ago
I have a plan that includes in Canada and in USA data. I entered the states today and I have not been able to use my phone until I reached wifi. When I go to turn data roaming on, it gives me an option to choose either off or my primary number. I don’t know why it says primary number as it’s my only number. But regardless I have no way to simply turn “data roaming on”
43m ago
@Handy1 wrote:I assumed OP already tried reseting network settings I said that in my first reply .
HI @Handy1 I assumed so too. But I seen in some cases that people need to Reset Network Settings multiple times to get things working
and if nothing helps, I think a trip to Apple store would worth it
Of course, OP can also test the PM sim card in another phone if he have one around
45m ago
I assumed OP already tried reseting network settings I said that in my first reply . Did you try reseting the network and or just reboot the phone @JenM86
48m ago
HI @JenM86
something not right, I don't think Koodo will lock the network carrier screen, only some US carriers did that
Again, start with Reset All networks, and you might want o remove your sim card and put it back in and see if that screen will come back out
Idea is it is better to test all 3 networks and see which one connects well
55m ago
iPhone 11. Got it from Koodo 3 years ago. After my contract ended I switched to public mobile.
an hour ago
HI @JenM86
where did you get your iPhone from? is that a Canadian model or US or one from another country?
Try Reset Network Settings first and see if the screen come back
if not, you might want to visit Apple store in your area as it is a device issue. Look like your device has some kind of lock somehwere
an hour ago
@JenM86 Maybe ask support if they can refresh your account on there end . That’s strange I don’t know why your missing the proper screen to select data roaming
an hour ago
Mine is saying 17.6.1 with no option to update on that screen
an hour ago
There is no option to choose a mobile network. After clicking cellular/mobile data this is the screen I get.
an hour ago
HI @JenM86
you meant the manual change network screen that you didn't see?
Settings > Mobile Data > Mobile Network.
By default, Automatic is selected. Turn off the Automatic option.
you will then see a list of available network. Try all 3 networks: T-Mobile, AT&T and Verizon
2 hours ago
@JenM86 Is your iOS up to date 18.0.1
2 hours ago
I do t have that screen. I think something got messed up when I switched to public mobile back in the summer
2 hours ago - last edited 2 hours ago
2 hours ago
These are my screens. There is no option
2 hours ago
hi @JenM86 make sure you have roaming data enabled
and try manually connect to T-Mobile or AT&T or Verizon and make sure network mode is 4g/LTE
2 hours ago
@JenM86 Maybe try to reboot the phone or reset network settings . You need data r paying on in phone settings . Also set phone to 4G/LTE not 5G and make sure your connected to T mobile or AT&T
