Data Not working on Unihertz Titan Pocket
Planeswalker
Mobile data is not working for me on the Titan Pocket:
https://www.unihertz.com/products/titan-pocket?variant=40602974126270
I have mobile data enabled under "Mobile Network" in settings and have tried rebooting the phone.
I found this thread with someone else having a similar issue (don't know on which carrier) but there does not appear to be a resolution:
https://www.reddit.com/r/unihertztitanpocket/comments/qdvzq9/titan_pocket_data_problems/
Does anyone have suggestions on how to get this to work?
2 REPLIES 2
Planeswalker
Figured it out. I had to enter the APN settings. I followed the instructions in this thread:
https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/Data-not-working/m-p/507807#M65773
data:image/svg+xml;charset=utf8,%3Csvg xmlns='http://www.w3.org/2000/svg' viewBox='0 0 1 1' width='100%25' preserveAspectRatio='none'%3E%3ClinearGradient id='a' x1='0' x2='0' y1='0' y2='1'%3E %3Cstop stop-opacity=' 0 ' stop-color=' %23fff ' offset=' 0%25 '/%3E%3Cstop stop-opacity=' 0 ' stop-color=' %23fff ' offset=' 100%25 '/%3E %3C/linearGradient%3E%3Cpath fill='url(%23a)' d='M0 0h1v1H0z'/%3E%3C/svg%3E
Thanks!
t_p
@Planeswalker
Do you have any data left on your plan?
Have you checked your APN settings?
Tried using 3G-only (WCDMA) ?
Tried a network settings reset?
If you have access to another phone, try swapping the SIM cards to see what happens.
For ref: Set up data on an Android phone (publicmobile.ca)
