2 hours ago
Hi, apologies if it's been asked already, but is anyone noticing their PM signal went down a lot? I typically get 4-5 bars, but now I'm hovering around 1 and sometimes none. I'm on the east coast (NL), in case that helps, and I'm using a Unihertz Titan Pocket (no recent config changes). SIM slot is fine/no dust, I've rebooted several times, reset settings, switched to 3G instead of 4G...nothing seems to help.
53m ago
one of the network cell in your area could be reset with other network, like 5G or down completely. The # of signal bars does not matter as long as no calls drops and data works
57m ago
Thank you for the reply! Do you know why the signal is weaker?
I haven't noticed any drops, though I don't do many calls. Texts go through but sometimes take a little longer than usual.
2 hours ago
the signal is weaker , but you experiencing dropped calls or lost of mobile data?
