08-17-2022 01:56 PM - last edited on 08-19-2022 12:54 AM by Dunkman
I have 1 GB of data monthly and when I look at my history it shows a lot of my data is being used in the middle of the night when I'm not using my phone. How do I stop this from happening??
08-17-2022 02:00 PM
@softech thank you for the help!
08-17-2022 02:00 PM
@PHastie hi check your setting make sure you have updates turned of for your apps while on data ,wifi only, also make sure wi fi assist is not enabled
08-17-2022 01:58 PM
@PHastie PM only upload data usage twice a day or so instead of constantly updating with many entries. So, the line you see middle of the night is a total usage since the last update (the previous line) rather than an actual usage during that time.
