Data Cap
41444167MC
Hi, I understand that some companies removed the data cap on their mobile plans. Has pubic mobile done anything similar to that? Thanks!
JoyLuck
If you are out and about and want to save data connect to a Shaw hotspot. Over 100000 of them in Canada.
"We’ve opened Shaw Go WiFi, Canada’s largest WiFi network, to everybody. Look for the Shaw Go network on your device and you can connect without a login or Shaw ID"
kselmak
Hi @41444167MC
We don't really have data caps in the same sense as postpaid services. We don't have flow of data, we get it in buckets
Unfortunately since there are no overages @41444167MC. There are no caps to lift. Here's a link on what the  telecom companies have done to help us out:  https://productioncommunity.publicmobile.ca/t5/Rewards/Data/m-p/516436/highlight/true#M14010
Triguy
PM does not have overages so once your data limit is reached then it stops.
