05-27-2022 03:43 PM
Hi,
I just paid my phone bill today to reactivate my phone. My phone is working now but my data is not working. My account is up to date and looks OK. Do you know what I can do?
Thanks, Jamie
05-27-2022 06:06 PM - edited 05-27-2022 06:07 PM
If you account is showing your data is up to date. Maybe it is your phone setting, you probably check already but is cellular data enabled?
Try rebooting your phone as well…hold down the power button and power off then power back on after 2 minutes.
05-27-2022 05:40 PM
Did anybody see the dar-signal in the Gotham sky? 🙂
05-27-2022 05:36 PM - edited 05-27-2022 05:52 PM
Ok I'm here now....what do you need?😁
Edit:
Ok seriously....if you just reactivated your account do you see your data counter on your overview page? If not did you recieve a data usage warning text?
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here ....for additional member supplied info.
05-27-2022 05:25 PM
It is very rare that the data counter doesn't get reset, so check your self serve as suggested as data can be chewed up pretty quickly. If it shows you have data and haven't used much then connect with a CSA to investigate.
05-27-2022 04:02 PM
@Jamie4 Do you see a line about data in your My Account 's My Data & Add-ons? If you do, try to reboot your phone once more
And you have data working in this phone before?
05-27-2022 03:50 PM
If you do have data left try resetting your network settings and reboot and check your Apn settings.
05-27-2022 03:45 PM - edited 05-27-2022 03:47 PM
Log in to your account / My Data and Add-ons to see if there's mention of data. If no mention of data...you've used it all until next renewal or you buy data add-on.
Edit..
which plan do you have ? You can burn through 250MB of data perdy fast.
