DATA NOT WORKING
Jossybaby83
My subscription was successfully renewed today - I can make calls and text messages - BUT DATA IS NOT WORKING!!!
Jossybaby83
Yes my plan was scheduled to change on renewal
HI @Jossybaby83 did you make a plan change today?  We saw many posts about data issue after plan change
you can try Reset all networks first
if that does not help,  please submit a ticket with CS Agent here:
Jossybaby83
tried it - nothing
Jossybaby83
it is
hairbag1
@Jossybaby83
make sure data is enabled in Settings
@Jossybaby83  Try resetting network settings see if that helps also check your APN settings
