02-27-2023 11:59 AM
I need a credit for add on bought by mistake but not used
02-27-2023 12:42 PM
02-27-2023 12:00 PM
please open ticket with PM CS agent, they will probably able to help
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
02-27-2023 12:00 PM
@emilylouiseswim Yes, it is possible if it never been used
Please open ticket with PM support using Chatbot:
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
02-27-2023 11:59 AM
@emilylouiseswim Explain to support they can help
- Get support by starting a conversation with virtual Chat box /SIMon. Click here
- you can send a private message To CS_Agents by clicking here.
Watch for reply top of page to the
Right ( envelope image )
