10-04-2022 08:47 PM
I am just wondering how long after you pay if your data reset? My end of bill date is today however my data has not reset and I had anticipated it resetting sometime this morning.
10-04-2022 10:40 PM
@softech wrote:
@not-trust-anyon wrote:your renewal tomorrow, after 12pm, and you will get new data.
@not-trust-anyon new data and voice minute (if applicable) will be applied shortly after 12 midnight EST
it's only the account status might got update later in the renewal process, usually done by 6am but can be as late as noon EST
While this doesn't apply to this specific situation, I do know of one exception to the above. If a customer has scheduled a plan change,the client's data counter will actually reset to zero usage again when the new plan takes effect.
10-04-2022 09:03 PM - edited 10-04-2022 09:04 PM
10-04-2022 08:54 PM
Thank you, it’s not the data on the my account or usage, it’s the actual data I’m not able to use
10-04-2022 08:50 PM
I’ll try this thanks!
10-04-2022 08:48 PM
10-04-2022 08:48 PM
@ReanneBraun , the renewal time is midnight eastern time. So, you have a few hours to go yet. Your account might not show the renewal being completed until sometime tomorrow.
