08-02-2022 12:21 AM
08-03-2022 10:44 AM
Yes....its been used for verification purposes for as long as I know and now that your account pin # is no longer securely secret its probably still one.
08-03-2022 09:20 AM - edited 08-03-2022 11:32 AM
So …. Do CS Agents have access to one's credit card info?
If they do have access -- keep in mind that they are Agents and not PM employees. On one occasion when I was communicating with a very nice and helpful CS Agent he told me that he was located in Poland.
08-02-2022 06:10 PM
08-02-2022 11:31 AM - edited 08-02-2022 11:33 AM
@Dunkman wrote:With the new My Account page, customers are not able to remove credit cards by themselves. You will need to contact customer service agent for help. You can deactivate pre-authorized payments yourself, but unfortunately unable to remove. You can also replace with another different card.
That's not right .... to hostage take your credit card info against your wish even if you don't wish to have auto-pay. And yes I know one could go through the hassle of contacting CS in order to remove the info.
08-02-2022 10:06 AM
@Timer wrote:contact to support team by private message CS_Agent to remoce it.
but you need to enter new info for credit card or just need to remove it.
@Timer PM prefers for customers to submit a trouble ticket through the chatbot SIMon first and if that doesn't work to then message the CSA's. Private messaging is not supposed to be the first method of contact as it doesn't get prioritized with all other trouble tickets
08-02-2022 02:44 AM
08-02-2022 01:57 AM
Because Jim Carrey and Jeff Daniels took over the redesign of the payment section of your self serve account on July 13th and with their combined wisdom made it much less user friendly than before requiring customer support to remove the payment card. If the act of replacing the current card with a $0 balance gift /credit card then you can use that option.
If you need card info I have several spent cards that I can share this info with you if needed. Just send me a private message otherwise contact customer support as instructed by @Dunkman to have your payment card removed from the account.
08-02-2022 12:37 AM
