Credit card change
rockinrod04
How to change a credit card number?
dabr
@rockinrod04   Log into your self serve account, click Payment tab and then scroll down the page and click Manage my Card option and either select Change my Card or Replace my Card.  Either option works well although some people have reported issues with one or the other.
Make sure to replicate name/address as on your CC statement leaving no spaces for postal code.
JK8
You can do this in self service.
Triguy
To set up AutoPay, sign in to your Self-Serve account, select the ‘Payment’ tab, then ‘Register for AutoPay’. From here, you can sign up for AutoPay or remove the feature, if you no longer want payments to automatically occur. If you would like to change the card that is automatically charged, scroll to the bottom of the ‘Payment’ tab, then select ‘Manage my card’. This will allow you to update or remove your credit or Visa Debit card.
