11-11-2025
02:03 PM
11-11-2025
05:57 PM
computergeek541
I recently lost the debit card that is used to pay my monthly fee. It took 3 days for a new card to arrive.
Before I had a chance to make the change to my account and add the new debit card, I received notice
from Public that my account was essentially suspending pending payment. No problem I thought - my new
card just arrived. Now all of a sudden, I'm paying almost $4 extra per month.
Is it possible to communicate with a human at Public Mobile?
11-11-2025 03:20 PM
how do you figure you're paying $4 more ? All of the old $15 plans are now $18 plus taxes and fees, so that may be what you're seeing.
Did you have referrals drop off and now you no longer get those Rewards. Did you upgrade to a different plan than original ?
11-11-2025 02:09 PM
Yes, you can talk to support directly, but via messaging
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
11-11-2025 02:09 PM - edited 11-11-2025 02:11 PM
@Obediah
You can add your new card to your via My Account portal, Payments, Manage Subscription then Manage Payment Method.
https://myaccount.publicmobile.ca/en/account/payment/manage-card
You can also contact a support agent using the link below.
Check messages here.
