4 weeks ago
- last edited
4 weeks ago
computergeek541
Hi @CS_Agent,
I live in Brampton west area and Public Mobile network has very poor mobile reception / signal strength in my area. Frequently pone calls are dropped or the other person can listen to my voice. Sometimes I can not ear him as voice is muffled.
Can you please improve the mobile signal strength in my area. If you need particular area information, I can provide as well.
Please let me know as I am facing problem everyday.
Tanks,
3 weeks ago
hmm @sheytoon,
A bit disappointing with the service in my area. Thx!
3 weeks ago
i @slusagm,
I ave reported it to CS_Agent. Thanks!
4 weeks ago
You can certainly report it to PM. They just can't fix it, so I wouldn't get my hopes up.
4 weeks ago
4 weeks ago
Brampton west L7A area. Adjacent to Fletcher's Parkette area.
Thanks!
4 weeks ago
Hi Softech,
Thanks for your reply. I just have submitted a ticket. Waiting or their reply.
Mobile: Google Pixel 6
Android version 16, Kernel version 6.1.1.34
It is compatible wit VoLTE technology.
If there is something I can try meanwhile please suggest.
Thank you!
4 weeks ago
@AshisBiswas unfortunately there is nothing Public Mobile or Telus can do about this. Coverage in Brampton is from Bell.
If coverage is a problem, you should consider Rogers or Freedom.
4 weeks ago
where exactly you are at?? I drive around Brampton daily and live far west (Mississauga Road) but no issue at all
4 weeks ago - last edited 4 weeks ago
what phone do you have?
Did you try Reset network settings on the phone?
And check if your phone is VoLTE compatible with PM network here:
https://www.publicmobile.ca/en/get-help/articles/volte
And you can also report your issue with PM CS agent, they can try to reprovision your account on the system and it could help. Please open ticket with PM support:
