05-20-2020 08:48 AM - edited 01-05-2022 10:50 AM
My sim card is inserted..my plan is activated and works on another phone...the new phone im trying to use is unlocked...but i cannot register to public mobile...its says unable to connect try later
05-20-2020 01:59 PM - edited 05-20-2020 02:00 PM
@Syl63 try changing your network to wcdma only, follow these steps:
Samsung Galaxy S3
05-20-2020 01:21 PM
Does your phone work with another active SIM card?
If your phone does not work with any SIM card, check here to see if your device has been blacklisted:
https://www.devicecheck.ca/check-status-device-canada/
05-20-2020 11:17 AM
It would still be extremely helpful if you provided us with the make and model of your phone. What exactly is the error message you are getting? You are sure your phone is unlocked because your former provider supplied you with the code and you performed that function yourself?
05-20-2020 11:15 AM
I had this when I first changed to public but after a few hours it was good to go. Maybe you need to wait. That was my experience.
05-20-2020 11:10 AM - edited 05-20-2020 11:58 AM
@Syl63 If the card works in another phone then you have an issue with your device. Try a factory reset and if it still doesn't work then time for a new new phone.
Factory reset Galaxy S3:
05-20-2020 10:55 AM - edited 05-20-2020 10:56 AM
Take a look if you can access these settings and check for your network operator.
If finding an answer is not an option I suggest considering a new budget/midrange option phone. This problem may be software or hardware as well.
Cheers.
05-20-2020 09:59 AM
@Syl63 Try these these steps to determine your Android version.
05-20-2020 09:51 AM
Cant find general management or reset network setting
05-20-2020 09:35 AM
@Syl63 Try resetting your network settings.
Restart your phone. Wait 30 seconds and restart it. See if it works. If it does, reenter your wifi if applicable. Also enable data and try sending an mms message to make sure your apn settings work properly. Welcome to the community. Stay safe.
05-20-2020 09:33 AM
Hi
What is make and model of your phone?
Where did you get it?
Was it used successfully with any provider that you know of.
It may still be locked actually
05-20-2020 09:33 AM
The APN only affects your data and MMS it has no bearing on calling or SMS texting. If your sim works in a different phone then the issue lies with your phone. What is the make and model? Are you 100% sure it's unlocked? There have many that have told that by their former providers only to discover it was an untruth.
05-20-2020 09:29 AM
I tried removing sim card and re starting
ive tried registrating with Bbell and Rogers..and then public. All of them say unable to connect...the furst two was instant error...the public mobile takes a while than says the same thing. I think my phone is galaxy s3
05-20-2020 09:13 AM
@Syl63 Try resetting your network settings and restart your phone. Some phones require a network rest to work properly. The make and model of your phone will help. But
In this case see if you can make a call.
05-20-2020 09:00 AM
Try removing and reinserting the sim. Also try rebooting your phone.
05-20-2020 08:57 AM
Trying turning the phone off removing the SIM then insert the SIM again and turn the phone back on.
You may need to reset your APN settings, if you have a Samsung then the settings will automatically reset.
You can also go into your network setting and manually select another network, it will give you an error, then go back in and select Public Mobile.
Lastly what phone do you have?
05-20-2020 08:51 AM - edited 05-20-2020 08:52 AM
@Syl63 wrote:My sim card is inserted..my plan is activated and works on another phone...the new phone im trying to use is unlocked...but i cannot register to public mobile...its says unable to connect try later
What do you mean? Where and when does it say unable to register? Where and when does it say try again later?
What make/model/submodel is the phone?
Can you scan for networks and find Public Mobile?
